Thread: New Grips
Created on: 12/23/09 09:32 PM
Tetrec
Tetrec's Gravatar
New Grips
12/23/09 9:32 PM
I've got a new set of anodized grips to install on the beast. Anyone have any tips for removal and installation?
slidderhd
slidderhd's Gravatar
RE: New Grips
12/24/09 10:14 AM
Does anyone know who might make oversized grips? I have large hands and would like something bigger than the stock grips.
Riding for the Son!
Its not about us, its about Him
RE: New Grips
12/24/09 8:08 PM
I would try wrapping your throttle grip to simulate a thicker grip. See how you like it first. You're bound to loose some fine throttle control if you do high R cornering.
RE: New Grips
12/24/09 8:11 PM
Tetrec, I have never removed hand grips but I believe they are glued onto the bar and they are a BEAch to get off. Good luck. Hope someone has some first hand experience to relay.
bgordon
Forum Administrator
bgordon's Gravatar
Grand Junction, CO
RE: New Grips
12/24/09 8:31 PM
I've replaced my grips. Cut the old ones off. Put soapy water inside the new ones and slipped them on. -bg
ninjamaster
ninjamaster's Gravatar
RE: New Grips
12/25/09 2:24 PM
Try some Grip Puppies.They slip over your exsiting grips.I've got the same problem with big hands.There nice with the heated grips too,the heat stays in them.
Your text to link here...
* Last updated by: ninjamaster on 12/25/2009 @ 2:26 PM *
Green means GO!!!!!!!!!!!!
2006 ZX14
2004 ZX10R
2004 Aprilia Mille Factory RSVR
2009 ZX6R Monster
1994 ZX7
1987 Yamaha YSR50
2003 ZX6RR
1986 Ducati 750 F1A
2008 KLR 650
1993 ZX11
1976 Honda CB550 Caferacer project
2011 Concours 14
2009 Aprilia RS125
2 pocket bikes(Blata and Vittorazi)they count too!!!!
RE: New Grips
12/25/09 3:18 PM
Hey Ninjamaster-I've been wondering where ya went!Hope everything's going well-MERRY CHRISTMAS!I asked about ya on another thread here-but now you're here so....did you ever get the reason why your 14 was starting weirdly?(or NOT starting,and dying on ya)?I got mine figured out(well,my mechanic found it).It was the Muzzy Ignition Advancer had come loose-not off,but changed the timing on me enough to give me fits trying to figure out WHAT was going on.Had my valves checked at the same time-24,000 miles and they were exact on the factory specs.That's when he noticed the advancer was moving when he tried to use the rotor to bump the engine.It all worked out fine though.Hope yours did also!I think I'm gonna give the grip puppies a shot here.Is that diameter going to change the way the throttle responds do you know?(just because the grip is now thicker with a larger O.D?)
* Last updated by: blue07 on 12/25/2009 @ 3:22 PM *
JMBJ
JMBJ's Gravatar
Foxfire Village, NC
RE: New Grips
12/25/09 6:49 PM
+1 on the Grip Puppies. I use them on all my bikes!
Tetrec
Tetrec's Gravatar
RE: New Grips
12/26/09 9:23 AM
Actually all went pretty smooth. A little wd-40 under the left grip made quick work of that. The color match on the se is good. Can't take an outside pic since we have snow and about -10degrees
* Last updated by: Tetrec on 12/26/2009 @ 1:35 PM *
ninjamaster
RE: New Grips
12/26/09 1:16 PM
Well it came down to the electrical connector to the fuel pump!I had the bike remapped in November(I put the hub on it and now have 2 maps).I need to recheck it cuz when we were doing the map the tank was loose and it shut off 3 times.
It's been awhile cuz I broke my wrist a week before Thanksgiving(fell 5 feet of a ladder)This has been the longest that I have not ridden a bike!!!The only thing I'm glad about is at least it's winter.
The grip puppies don't change anything(that I've noticed)The only problem I have is with the heated grips it warps the throttle tube a little.Nothing a little squirt or lube doesn't fix!!
* Last updated by: ninjamaster on 12/26/2009 @ 1:18 PM *
2006 ZX14
2004 ZX10R
2009 ZX6R Monster
1994 ZX7
1987 Yamaha YSR50
2003 ZX6RR
1986 Ducati 750 F1A
2008 KLR 650
1993 ZX11
2011 Concours 14
2009 Aprilia RS125
RE: New Grips
12/26/09 2:06 PM
Glad yer doing okay there Ninjamaster-and that your baby got fixed back to the "reliable" stage.I hate riding and thinking about"geez...is this gonna fail,or that".I really don't worry about that kind of thing with my Ninja.(although I did when she was acting up-that's why I parked her!).Sorry about you leg-but glad it's healing well.Hard not to go ride-yep-spring's comin though.I'd like to get to the Beartooth this coming new year.Perhaps see ya there sometime?
ninjamaster
RE: New Grips
12/26/09 4:01 PM
That would be cool.I think my info is in the travel help thread!I miss riding
2006 ZX14
2004 ZX10R
2009 ZX6R Monster
1994 ZX7
1987 Yamaha YSR50
2003 ZX6RR
1986 Ducati 750 F1A
2008 KLR 650
1993 ZX11
2011 Concours 14
2009 Aprilia RS125
RE: New Grips
12/26/09 8:09 PM
I use an air gun to remove and install grips. Blow air between grip and bar and the grip is off or on to your choice.
imrubicon
imrubicon's Gravatar
RE: New Grips
12/27/09 3:49 PM
Air hose shoved under the grip will losen them up also without putting oil on the bars
Lost in TX and I dont want to be found ,
2012Yamaha Tenere 1200 for really wandering off the beaten path
2005 GL1800 Sold to another to enjoy
2006 ST1300 Gone but not forgotten
2009 ZX14 Also gone and will be replaced someday
some of the best of both worlds
loadedmind
loadedmind's Gravatar
RE: New Grips
01/17/10 1:43 PM
Hi all. New guy from North Alabama here. I have the candy burnt orange/black SE '09. I have the Johar sportbike grips on mine. The installation was pretty simple. I just used a pair of scissors and pliers to get the old ones off. Basically, start at the part of the grip where your thumb and index finger go and cut a snip into the rubber. Use your pliers to pull it back a little bit, cut some more, pull back, repeat. To install the new grips, I just cleaned the area after removing the factory grips which is just a gray plastic (kinda cheap feeling) slick grip. Then I used my wife's hairspray to lightly coat the plastic and immediately afterward, I pushed the new grips onto them. I waited about 8 hours before I rode, but it said to wait 12-24. The Johar instructions actually said to use hairspray, if you can believe it. They're quite comfy if not just a tad too spongy. Meaning, they give a little too much, but I haven't found anything even remotely close to these for comfort/usability. I have a video of it somewhere if you need to know how I did it.
Here's a link to them if you'd like to see what they look like:
http://www.bikebandit.com/johar-superbike-grips
* Last updated by: loadedmind on 1/17/2010 @ 1:47 PM *
RE: New Grips
01/17/10 4:19 PM
, Loaded!
loadedmind
RE: New Grips
01/17/10 8:01 PM
Thanks Rook!
privateer's Gravatar
RE: New Grips
01/19/10 3:57 AM
Hey, loaded, where in "Northern Alabama" ? I spent a couple years at Redstone in Huntsville, loved it there! Close to TN also.
Living the Gypsy Life
loadedmind
RE: New Grips
01/19/10 12:38 PM
Same area privateer.
buck20
buck20's Gravatar
RE: New Grips
01/20/10 1:41 AM
I use the driven grips. Check them out! I dont think you can find higher quality. They came free with my pazzo levers from motor mummy so I put on the package deal, man talk about nice. I was so impressed I bought another set for my GSXR.
To much to list!
loadedmind
RE: New Grips
01/20/10 9:28 AM
buck20: I've seen those, but I much prefer the extra padding Johar grips afford. Here's a pic:
http://www.bikebandit.com/assets/product_images/09JoharSuperbikeGLG.gif
buck20
buck20's Gravatar
RE: New Grips
01/21/10 4:08 AM
I looked at them and I think they might be a little too smushey for me!
To much to list!
